Can someone identify this mod ?
E5911
the lower desert
Can someone identify this. The radio is a 3061t I got used, radio seems to work ok, but the included antenna. Looks like a setup to run a external vhf antenna.
1-Can I remove it?
2-Is there a screw on adapter to use a bnc type antenna
Looks like it's the wrong antenna. That doesn't look like an adapter on the radio, it looks similar to my Icom radios.
What does the underside of the antenna look like? Any marking on it?
You can get BNC adapters, however they are intended for bench testing and not recommended for daily use. the extend the length of the antenna mount and put strain on the connector/solder joint. You'd be doing your radio a favor by just getting the correct antenna rather than using an adapter.
gh6406
Dalton,Ga
kny2xb
North Clearwater, FL
