Can the KPT-d1n be used on a virtual machine
fontanei
FL
I have not found a thread discussing this...
Closest thread has been: moving kpg-d1n to another machine
I have been recently thinking my laptop is going to die prematurely (taking along programming software and licenses) and to avoid that I am thinking of converting my physical hd into a virtual (P2V) one to run it in a kvm hypervisor (virtual machine) using clonezilla.
Has anyone tried this?
otobmark
NC
the question is what does the cps use to identify/authorize the computer it’s on. If the identifiers are computer hardware then opening the virtual machine on different hardware may not authenticate the cps. If the identifiers are within the operating system itself then maybe it would work.
tweiss3
Is it time for Coffee?
Ohio
You are probably better off just deauthorizing the license when you are done using it. Not saying it won't work, but you never know until you try.
kd4efm
EL98 Florida
Not recommended, because the VM changes machine ID. The LMC is based on the MEiD.
Use at such time yeah, but long term, not a good deal.
otobmark
NC
Real solution is for kenwood to abandon the entire scheme. Even “bleed em dry” Motorola doesn’t do this. In PS something not working when it should is almost always greater concern than working when it shouldn’t. Plan for the unexpected…
fontanei
FL
I was playing around with the MEID last night and it turns out that you CAN clone a MEID.
TODO: clone and convert physical hd and try running it in a KVM hypervisor (linux).
MTS2000des
5B2_BEE00 Czar
Agreed. If MSI can give away APX and CPS2, JVC Kenwood is just being greedy and making life hard for the customers bleeding them. MSI makes up for it with the cost of subscribers, so they can gift CPS and get it back when you buy the hardware. KPG-Dx licensing system sucks worse than Microsoft Windows licensing.
