Hooterville
- Joined
- Dec 3, 2007
- Messages
- 44
Post Removed !
Post removed.
Post removed.
NOTE: Didn't mean to "hijack" this thread but since the OP removed his post, I thought it would be a good time to raise awareness about this subject
This is a good question to bring up, mainly to raise awareness that there's so many phones out there advertised as digital operating in the 2.4GHz and even 5.8GHz band but you can still pick them up in the lower bands in analog.
I recently was near a brand new Uniden 5.8GHz phone that suddenly started coming through in analog around 921MHz on my scanner. I looked in the manual and nowhere in there it says it's even digital or that it strictly operates in the 5.8 GHz band only.
So for those that don't know, make sure the phone you buy uses some sort of digital Spread Spectrum technology i.e. DSSS or FHSS, otherwise it's likely that it's dual or even triple bander using analog (and different bands) in one direction or the other.
The latest technology now is those 1.9GHz DECT 6.0 phones. Supposedly they're better in that they operate in a less crowded band and use pure digital and even heard it uses encryption but I haven't research it yet to know for sure.
EDIT: Here's some more info about DECT: http://www.dect.org/content.aspx?id=18
It seems that it does in fact uses encryption and TDMA. It uses frequencies between the 1921-1929MHz range.
EDIT: Here's some more info from Wikipedia about DECT: Digital Enhanced Cordless Telecommunications - Wikipedia, the free encyclopedia
It says the encryption used is "weak" but I would think something is better than nothing and it might be more work than its worth in most cases to try and "hack" the algorithm......
Here's an excerpt:
" [DECT] provides encryption services with the DECT Standard Cipher (DSC). The encryption is fairly weak, using a 35-bit initialization vector and encrypting the voice stream with 64-bit encryption."
EDIT: Here's another source actually stating that DECT encryption is in fact "very secure":
Page not found..
EDIT: Here's some more info from Wikipedia about DECT: http://en.wikipedia.org/wiki/Digital_Enhanced_Cordless_Telecommunications
Here's an excerpt:
Page not found. Can we help?
