Can you tag TG's (DSD Plus/Fastlane)
bobruzzo
W1AV
Cranston, Rhode Island
Can you tag talk groups that appear while scanning systems? I get a bunch of TG's that are easily identified but can you edit or make a file with the identified TG's?
a417
edit the DSDPlus.groups file.
As it says, you may edit & save it while DSD+ is running, and it gives you the field by field format of each entry.
BM82557
Berkeley Co WV
Example of part of my group file --
P25, BEE00.441, 5540, 42, Normal, 24, 2020/09/12 13:32, "City PD Call 1 Dispatch"
P25, BEE00.441, 5541, 50, Normal, 100920, 2020/09/12 20:26, "City PD Call 2 Primary Dispatch"
P25, BEE00.441, 5542, 50, Normal, 1473, 2020/09/12 18:37, "City PD Call 3 Alternate Dispatch"
P25, BEE00.441, 5543, 50, Normal, 4955, 2020/09/12 20:14, "City PD OPS 4"
P25, BEE00.441, 5544, 50, Normal, 1066, 2020/09/12 19:42, "City PD OPS 5"
P25, BEE00.441, 5545, 50, Normal, 3, 2020/09/12 20:05, "City PD TAC 6"
P25, BEE00.441, 5546, 50, Normal, 150, 2020/09/12 19:31, "City PD TAC 7"
P25, BEE00.441, 5547, 50, Normal, 1, 2020/09/11 14:33, "NOT IN DB"
P25, BEE00.441, 5548, 50, Normal, 0, 2020/09/11 10:08, "NOT IN DB"
P25, BEE00.441, 5551, 50, Normal, 76, 2020/09/12 3:45, "City PD Encrypted"
P25, BEE00.441, 5552, 50, Normal, 5, 2020/03/03 15:32, "NOT IN DB"
P25, BEE00.441, 5570, 50, L/O, 20, 2020/09/11 13:32, "City Services Departmentwide 1"
P25, BEE00.441, 5571, 50, L/O, 3, 2020/09/11 14:35, "City Services Departmentwide 2"
P25, BEE00.441, 5572, 50, L/O, 7, 2020/09/11 12:06, "City Services Engineering"
P25, BEE00.441, 5573, 50, L/O, 114, 2020/09/12 9:32, "City Services FCCA"
P25, BEE00.441, 5574, 50, L/O, 9030, 2020/09/12 20:25, "City Services General Services"
P25, BEE00.441, 5575, 50, L/O, 3261, 2020/09/12 20:25, "Parking"
P25, BEE00.441, 5576, 50, L/O, 147, 2020/09/12 14:31, "City Services Parks"
P25, BEE00.441, 5577, 50, L/O, 4945, 2020/09/12 20:26, "City Services Sanitation"
P25, BEE00.441, 5578, 50, L/O, 626, 2020/09/12 2:09, "City Services Streets"
P25, BEE00.441, 5580, 50, L/O, 2832, 2020/09/12 20:13, "City Services Water/Sewer"
P25, BEE00.441, 5668, 35, Normal, 48513, 2020/09/12 20:11, "MD State Police Barrack B Frederick OPS"
P25, BEE00.441, 5669, 50, Normal, 635, 2020/09/12 16:42, "MD State Police Barrack B Frederick Tactical"
P25, BEE00.441, 5670, 50, Normal, 0, 0000/00/00 0:00, "NOT IN DB"
P25, BEE00.441, 5671, 50, Normal, 0, 2020/09/09 18:39, "MD State Highways CHART TOC 7 OPS"
P25, BEE00.441, 5672, 50, Normal, 0, 2020/09/12 18:39, "MD State Highways CHART TOC 7 Traffic"
P25, BEE00.441, 5673, 50, Normal, 6, 2020/09/12 7:01, "MD State Highways CHART"
u2brent
KRWDPAXKRS1
Type the TGID tag/name in between the two quotation "" marks at the end of each groups line in the groups file.
"TGID xxx"
a417
OK so I have a bunch of data in my "dsdplus.groups" file.....for example there are about 35 lines from talkgroup "134" but do I have to name EVERY ONE in that series of 134 TG's? In other words can I enter the TGID name ONCE for TG 134?
You sure you opened the DSDPlus.groups and not DSDPlus.radios? And if you're in the right file, are you sure you are in the correct column?
There should be a single entry per TGID per system.
I have a feeling that you're conflating things here, if you want to ID the talk group, you want to be in .groups. If you want to ID specific subscriber units, you need to be in .radios
u2brent
KRWDPAXKRS1
You must be looking at something wrong :unsure:
there can only be one TGID with that number on a system.
you sure that's not the Network ID, Goups look like this..
Code:
NEXEDGE48, 50,        17000,      50,  Normal,    3909,  2020/08/24 15:46,  "Bear Materials Concrete"
NEXEDGE48, 50,        17001,      50,  Normal,       3,  2019/08/16 18:04,  "Colonial Airport Park & Ride Shuttle Bus"
NEXEDGE48, 50,        17002,      50,  Normal,     362,  2020/08/24 15:46,  "Excavation/Paving?"
NEXEDGE48, 50,        17003,      50,  Normal,       1,  2017/09/01  6:12,  "?"
NEXEDGE48, 50,        17004,      50,  Normal,      43,  2019/04/12 17:12,  "?"
NEXEDGE48, 50,        17200,      50,  Normal,       0,  0000/00/00  0:00,  "Chichester School District Buses"
NEXEDGE48, 50,        17201,      50,  Normal,       0,  0000/00/00  0:00,  "?"
NEXEDGE48, 50,        17300,      50,  Normal,      48,  2019/08/19 20:55,  "Wyshinski Bus Service"
NEXEDGE48, 50,        19000,      50,  Normal,   12421,  2020/08/24 15:36,  "Sutton Bus & Truck Co"
NEXEDGE48, 50,        19001,      50,  Normal,      84,  2017/09/01  8:59,  "Sutton Bus & Truck Co"
NEXEDGE48, 50,        19003,      50,  Normal,       6,  2019/08/30 15:13,  "Sutton Bus & Truck Co"
NEXEDGE48, 50,        20244,      50,  Normal,       1,  2019/08/16 11:52,  "?"
NEXEDGE48, 50,        21002,      50,  Normal,       0,  0000/00/00  0:00,  "Payless Airport Shuttle"
NEXEDGE48, 50,        21101,      50,  Normal,     318,  2019/08/19 16:34,  "A-1 Sanitation Service Inc?"
NEXEDGE48, 50,        21150,      50,  Normal,      65,  2019/08/19 23:01,  "?"
NEXEDGE48, 50,        21176,      50,  Normal,     220,  2019/08/19 14:47,  "Fuel Supply?"
NEXEDGE48, 50,        21201,      50,  Normal,       0,  0000/00/00  0:00,  "Agri Business?"
NEXEDGE48, 50,        21300,      50,  Normal,    2059,  2020/08/24 15:31,  "RPJ Waste Services Inc"
NEXEDGE48, 50,        21301,      50,  Normal,    1511,  2019/08/19 21:27,  "Primecare MedTrans"
NEXEDGE48, 50,        21500,      50,  Normal,      48,  2019/08/12  7:20,  "Wallingford-Swarthmore SD Bus"
NEXEDGE48, 50,        21550,      50,  Normal,       0,  0000/00/00  0:00,  "?"
NEXEDGE48, 50,        21600,      50,  Normal,     256,  2019/08/19  7:56,  "School Bus (N Wilmington Area)"
NEXEDGE48, 50,        21601,      50,  Normal,       1,  2019/08/15  8:23,  "School Bus"
NEXEDGE48, 50,        21602,      50,  Normal,       3,  2019/08/19 10:41,  "?"
NEXEDGE48, 50,        21800,      50,  Normal,    1230,  2020/08/24 15:40,  "WilmDE Concrete/Paving Co"
NEXEDGE48, 50,        22000,      50,  Normal,     601,  2020/08/24 15:36,  "Delaware Electric"
NEXEDGE48, 50,        23000,      50,  Normal,    3261,  2020/08/24 15:46,  "Harris Towing"
NEXEDGE48, 50,        23001,      50,  Normal,       1,  2017/09/01  4:04,  "?"
NEXEDGE48, 50,        23002,      50,  Normal,       1,  2017/09/01  2:01,  "?"
NEXEDGE48, 50,        24000,      50,  Normal,       0,  2017/09/01  2:28,  "Dumpster svc"
; Triangle 800 DMR
DMR,       5,         100,        50,  Normal,      17,  2020/04/21 13:58,  "Triangle800 TG100"
DMR,       5,         103,        50,  Normal,       0,  0000/00/00  0:00,  "Triangle800 TG103"
DMR,       5,         200,        50,  Normal,       0,  0000/00/00  0:00,  "Triangle800 TG200"
DMR,       5,         33892,      50,  Normal,       0,  0000/00/00  0:00,  "Triangle800 TG33892"
; Freese DMR
DMR,       6,         10,         50,  Normal,       0,  0000/00/00  0:00,  "Freese CH2 Talkaround TG10"
DMR,       6,         60,         50,  Normal,       0,  0000/00/00  0:00,  "Freese Towing? TG60"
; Herr Foods DMR
DMR,       7,         10,         50,  Normal,       0,  0000/00/00  0:00,  "Herr Foods TG10"
Cap+,      0,         102,        50,  Normal,       0,  0000/00/00  0:00,  ""
; Mid Atlantic Digital
Con+,      141,       102,        30,  Normal,       1,  2017/08/23 12:25,  "Radio Technicians"
Con+,      141,       200,        30,  Normal,     122,  2019/01/11 14:27,  "Radio Technicians"
Con+,      141,       214,        30,  Normal,      19,  2017/08/28 17:53,  "Radio Technicians"
Con+,      141,       215,        30,  Normal,      35,  2017/08/29 14:31,  "Radio Technicians"
Con+,      141,       216,        30,  Normal,       1,  2017/08/23 12:14,  "Radio Technicians"
Con+,      141,       223,        30,  Normal,       3,  2017/08/22 12:26,  "Radio Technicians"
Con+,      141,       230,        30,  Normal,      23,  2017/08/31 15:13,  "Radio Technicians"
Con+,      141,       344,        50,  Normal,       1,  2018/10/26 10:04,  "Harrisburg School Bus"
Con+,      141,       400,        40,  Normal,      16,  2017/10/06 21:42,  "York School Bus"
Con+,      141,       530,        60,  Normal,     390,  2019/12/29 14:05,  "Discover Lancaster Tours"
Con+,      141,       531,        60,  Normal,       7,  2017/08/25 13:25,  "Discover Disp Private"
Con+,      141,       532,        60,  Normal,       4,  2017/08/26 14:04,  "Discover Bus 5 Private"
Con+,      141,       533,        60,  Normal,       1,  2017/08/27 15:01,  "Discover Bus 2 Private"
Con+,      141,       535,        60,  Normal,       5,  2017/08/25 10:37,  "Discover Bus 4 Private"
Con+,      141,       536,        60,  Normal,       2,  2017/08/26 12:01,  "Discover Bus 1 Private"
Con+,      141,       574,        60,  Normal,      10,  2017/08/27 16:58,  "Discover Bus 6 Private"
Con+,      141,       645,        40,  Normal,       4,  2018/10/26  7:43,  "Produce/Ag"
Con+,      141,       650,        30,  Normal,     181,  2017/10/06 15:55,  "Plumbing/HVAC/General Contractor"
Con+,      141,       670,        30,  Normal,       3,  2017/08/21  8:43,  "?"
Con+,      141,       680,        50,  Normal,      14,  2017/09/08 13:12,  "Ag"
Con+,      141,       730,        50,  Normal,      25,  2018/11/23  0:38,  "Ag"
Con+,      141,       760,        45,  Normal,     396,  2017/10/05  9:28,  "Marstellar"
Con+,      141,       800,        60,  Normal,     551,  2019/09/18 14:31,  "Rover"
Con+,      141,       801,        60,  Normal,       5,  2017/08/23 15:17,  "Rover2"
Con+,      141,       900,        50,  Normal,     566,  2019/08/09 15:36,  "Ag"
Con+,      141,       945,        40,  Normal,      40,  2018/10/26 14:26,  "Pool/Community Maintenance"
Con+,      141,       2020,       30,  Normal,      12,  2017/09/06 12:59,  "Radio Technicians"
Con+,      141,       2045,       55,  Normal,    1097,  2019/01/11 14:45,  "Weaver Construction/Main"
Con+,      141,       2065,       40,  Normal,      44,  2018/10/26 13:10,  "Eshelman Trans Bus (Berks Co)"
Con+,      141,       2125,       30,  Normal,      35,  2017/08/29 10:18,  "Radio Technicians"
Con+,      141,       2160,       50,  Normal,     358,  2019/01/11 15:05,  "Ag"
Con+,      141,       2180,       50,  Normal,     698,  2019/01/11 14:28,  "Ag"
Con+,      141,       2195,       50,  Normal,      33,  2018/10/26 14:55,  "Ag"
Con+,      141,       2196,       50,  Normal,      25,  2017/10/04 20:44,  "Ag"
Con+,      141,       2218,       30,  Normal,       5,  2017/08/29 14:15,  "Radio Technicians"
Con+,      141,       2250,       30,  Normal,       1,  2017/09/08  8:12,  "Construction?"
bobruzzo
W1AV
One more thing I thought of. Can you set the TGID names in ANOTHER COLOR? All the text is GREEN and it would be cool if the actual name of user appeared in a contrasting easier to see color.
bobruzzo
W1AV
Yes I got it ok, I was looking at the WRONG NUMBER. I set all the ID's and it is working perfectly. I posted again a few seconds ago asking if it is possible to change the color of the TGID names. All text is in green and it would be nice to customize the display. Just change the name of user to a different color.
bobruzzo
W1AV
Code:
; Triangle 800 DMR
; Freese DMR
; Herr Foods DMR
Yes I was looking at the wrong number, once I saw that I realized my mistake. So I was able to set all the names with no problem.
u2brent
KRWDPAXKRS1
Nope, Can't do that..
a417
I have a quick patch for OP25 to do just that, but it won't help us here.
