Canadian Border
vant6
I live near the bridge in sarnia, anyone know of any canadian customs or or U.S border frequencies around here?
Jay911
Silent Key (April 15th, 2023)
Bragg Creek, Alberta
While the TAFL may not show you any such frequencies due to its policy of not containing 'sensitive' or 'protected' information, the agency you're looking for in Canada's case is called the Canadian Border Services Agency, or CBSA. I don't browse the Ontario database often enough to know if anyone's logged CBSA freqs for your area. You might also want to check the database sections for the state that you'd be in if you crossed over the border.
seamusg
Grand Blanc, MI
You might want to see if you can get the MPSCS system.
http://www.radioreference.com/modules.php?name=RR&sid=100
The rail crossings near Sarnia get busy at times. Look under Federal Government Talkgroups. I've heard TG 2380 CANUS C.B.S.A./U.S.B.P. - Common, a few times plus the USBP TG's
ocscan
Ottawa, On
Cbsa
Try these out, some may be APCO25 now...
152.4800 Repeater Canada Wide
154.6500 Simplex
410.3875 Repeater and Simplex
410.4375 Repeater and Simplex
410.4625 Repeater and Simplex
410.7875 Repeater and Simplex
425.5625 Simplex
425.6875 Simplex
DaveH
Ottawa, Ont.
Interesting thing is that CBSA (spelled out fully) shows multiple licences
in TAFL, but not always for the area of use. For example, Ottawa is not
listed on 410.4625 but it shows up in some other location(s). Plugging
in all the frequencies should reveal at least some active. Also, 410.4375
seems to be active in the Kingston area. I also see some simplex in the
415MHz range (415.6125).
Dave
Forts
Ontario, Canada
Also check out US Border Patrol on 163.625 and 163.675. They are quite active in the Pt. Huron area. They are usually P25 digital though, so you will need a digital scanner.
ocscan
Ottawa, On
From TAFL;
121.900000 PEARSON INT'L AIRPORT Canada Border Services Agency Radio
151.730000 ONTARIO-WIDE Canada Border Services Agency
Nothing monitored on these yet.
grasshutt
How about Windsor / Detroit Bridge or Tunnel ? Would that also be under CBSA ? or Customs ? I live within eyesight of the bridge and i often see the white pick-ups with lights on top but never see any marked /unmarked police vehicles just windsor police parked in the duty free... thanks GrassHutt
VA3DBJ
Ontario Database Admin
Durham Region, Ontario
US Border Patrol on 163.625 is active in the Buffalo/Rochester area with a PL of 100.0. They are also in the clear.
