Cannot connect to RR's database
padre29
I have a BC396D and I am having a problem connecting to the RR database to update the digital freq's.
I've tried Bctools and received and error message, and tried Proscan and the program tried to connect to RR and it never completes the connection.
The BCD has the older serial cable and I can access the database as a premium member.
Firmare version is 3.02.02.
Can someone point me in the proper direction to solve this?
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
More correctly;
ScanNow.org - The Home of FreeSCAN!
for FreeScan - but ProScan should work just fine. We have a reserved thread for ProScan issues called the 'Official ProScan Software Thread' (don't just look at new posts, or it's likely you won't see it) - please post there, and be specific about the error message you get. Bob is here frequently, so it shouldn't take long to get an answer
73 Mike
Saint
Fort Erie Ontario Canada
RR Problems
Bctool will not work with the import function, the author of the program is in the middle of re-writing the whole Bctool program and when finished the new Bctool will be released to the public for free.
Steve
padre29
Steve
Thanks, I found a work around using Mozilla and Cut and Paste though.
The download function may not work correctly, C&P into a New System did.
Now if only I could get the APCO25 system to work properly, it seems to be slightly off, I'll receive the first portion of a Digital transmission but the scanner then just stops following the signal.
As for "how" with BcTools:
Open Firefox>connect to the internet>radio reference>database>right click on desired channels>copy>close mozilla>BcTools>open programming>export to>new system>left click>choose paste.
