I have a problem with a MCS2000 that I acquired recently: type MR304A, model M01KHN9PW5AN (version III), 136-174 MHz.
The radio works, but when I try to read the codeplug, the CPS displays the message: "Error reading from image when attempting to unpack block Hardware Configuration Block Unpack failed." I use the CPS version R02.03.00 (original) with a RIB-interface that works fine with several other MCS2000s that I have.
Among these, I have a MCS2000 138-174 MHz with a 1-line display (version II), but I would like to use a version III radio with a 2-lines display, and that's why I bought this one. I tried to replace the 1-line display head on my previous radio with the 2-lines display head from the new radio and everything seems to work normally, but the second line remains blank and the CPS still recognizes the radio as a version II radio, so I cannot program the second line anyway.
I saw an old thread here on RR regarding the same problem, but no real solution was given. Since that thread is from 2011, I would like to hear if a solution to this problem has been found more recently?
FS
FS
