Cannot Turn On CSV File on TYT MD-2017
allandunn
Gardner, MA
I downloaded the database of users from DM-MARC, edited it down to list users in only nine states,, removed the last column, and added the dummy Nickname column. That CVS file was added to the code plug file, saved,and written to the radio. According to You-Tube videos, the last step should be to activate it with the 14th selection in the Menu/Utilities/Radio Settings tree within the radio. Problem is there is no 13th or 14th listing in that tree.
Radio has D0030.0040 10,000 users firmware and CP V01.22. PC runs Windows 10.
Am I doing something wrong? Or is there a bug in the code plug software?
eaf1956
Evansville, IN
The CSV firmware is 100,000 contacts, sounds like you got the REC firmware loaded.
Current Firmware V004.005 with CPS version 1.22
allandunn
Gardner, MA
https://forums.radioreference.com/budget-entry-level-transceivers/364895-cannot-turn-
I thought the latest firmware on the TYT site was D003.040. Have to look more carefully for the xxx.050 version. But I never can find the 100,000 version of it for the MD-2017; I will have to look again. Thank you.
