Every post I have checked seems that if there was a problem, it has been corrected. I however cannot get the update to take place. All I get is the standard communications error screen.
I have done everything required several times these include:
Re-downloading the update and installer
Checking com ports and verifying I CAN control scanner through the said com port
Verify baud rate is the same
Push 6 and l/o when turning on by front knob and by supplying power from the rear
I have completed one update prior to the current on, with no issues.
Any suggestions are welcome. Reading about this update it will hopefully improve the poor issues with my local P25 systems.
Thank you
Thank you
