Can't get this radio workin
noodlebot
Hello guys
I have recently purchased this radio/scanner/walkie set
Long Range Walkie Talkie Set - 3-5 km Range, UHF, VOX, 110v - BitRoad
and cannot get it to work at all. I have tried following it's instructions and it will not seem to stay at the frequency i set it at. it simply goes back to 400.00 if i touch anything else after typing, or wait a few seconds.
Also the lowest it seems to go is 400.00, and highest is 469.99 and it has the power to 50 above that
Please any help here would be appreciated, am trying to get to frequency 138.46
I'm sure this walkie can do it, it has dual band, lots of settings and a very confusing manual.
mikewazowski
Forums Manager
Oot and Aboot
I've moved your post to a more appropriate forum than Scanner and Receiver Reviews. Please review all available forums to make sure that where you are posting is appropriate. Thanks.
From what I can see this is a single band UHF radio. It will never do that VHF frequency you are trying to out into it.
n0nhp
Grand Junction
Right on the page you link to "UHF Frequency Range (400-469.995MHz)"
These radios are not dual band and will not do VHF
Time to do your homework before pushing the order button.
Bruce
jaspence
Michigan
UHF walkie talkies
Any transmission on those radios requires a license of some type. Some of the frequencies it can produce are in the public safety range and could land you in big trouble.
If you are entering the frequencies by hand, make sure you save them to memory before enter a second frequency or turning it off. Many of the Chinese radios are much easier to program with the proper software and cable.
kayn1n32008
ØÆSØ
Sector 001
Wirelessly posted (Mozilla/5.0 (BlackBerry; U; BlackBerry 9900; en-US) AppleWebKit/534.11+ (KHTML, like Gecko) Version/7.1.0.1047 Mobile Safari/534.11+)
Coorrect, BUT the equipment cannot have a removable antenna, must transmit in narrowband, and cannot exceed .05w, nor can it operate on any other frequencies out side of part 95. It also must be type accepted for part 95 use. All of which that radio does not do. Except possibly transmit NB.
W8RMH
Feed Provider Since 2012
Hello guys
I am curious as to what led you to believe these radios were dual band?
Also the legalities would depend on the OPs' location.
N8IAA
Fortunately, GA
I'm going to presume that the OP is in the UK, or Australia. They have a UHF CB band that these radios will work.
Also, since it stated UHF in the description, how did you get dual band?
Larry
noodlebot
It says this is a dual band transciever in the manual that comes with it. I'm assuming Wide and Narrow are the "2" different types
I am no pro in radios or anything. I just want a set of radios I can use to pickup on police communications, to have them in a backpack, sort of like a bugout bag/survival bag.
I am sure these walkies will work for what I'm trying to do however I can't get it to do so
noodlebot
And one last thing my manual for this walkie set says:
VHF Frequency range/136-173.995MHz
UHF Frequency range/400-469.995MHz
So I must be able to change this range somewhere?
KevinC
Other
Home
As has been pointed out, the link you provided states...
...if you believe they are supposed to operate on different ranges I would contact the seller and ask them. If the specs are for the radio you have it won't work on 138.xxx.
KevinC
Other
Home
At least now you know what to look for in the next ones you purchase. :D
KevinC
Other
Home
noodlebot
Again as I said I'm not familiar with this at all. I just want a handheld to be able to access that frequency. Can't be running around with a CB, and not aware of what trunking is.
