KeithJoseph
Still working on my amateur radio callsign.
I haven't heard my local railroad key up in awhile.. Abilene,tx area..did they go to nxdn
It would help if we knew what railroads you are referring to.I haven't heard my local railroad key up in awhile.. Abilene,tx area..did they go to nxdn
It's a discone antenna and no I can't get the nxdn freq but everything else yesIt could just be a reception problem, usually the dispatches are using a tall tower to broadcast, the crews are on the ground, possibly transmitting with less power as well.
What kind of antenna are you using?
I have also seen in some areas where the dispatcher and crew are on two different AAR channels. Does your scanner have the ability to scan the entire railband? I programmed all 97 AAR channels into one of my handheld scanners so I can scan in areas when I'm not sure what channels are being used.
