Win500: Can't import Wisconsin statewide conventional
djeplett
NE Wisconsin
Think I found a bug in the web import feature of Win500. If I go to Web Import -> RadioReference.com -> Conventional Frequencies
Then hit START
Then pick State/Province Wisconsin
and then for County select Statewide I immediately get the error box:
And if I click OK I get the error box once again, and then if I click OK once more it goes away and sends me back to the County selection.
Now, there should be conventional stuff listed for Wisconsin:
https://www.radioreference.com/apps/db/?aid=1006
And, if I try this in Sentinel it works and I can import the stuff listed on the previous linked page under any county -> Statewide -> Conventional Interoperability.
So Win500 has a bug in it, as the data can be imported in Sentinel.
hiegtx
Dallas, TX
Then hit START
Win500 works, but not in the manner you expected.
Instead of selecting the county field, and then choosing "Statewide" under that, instead, leave the county designation at <select>
You might need to hit the Start key again, to kick-start the selection process, but this iis where you'll end up, with your statewide conventional systems shown:
