Last night I was able to listen to Cleveland’s GREATER RADIO COMMUNICATION NETWORK. It just started but for some reason this morning it stopped. I live in TRUMBULL COUNTY and usually can’t monitor that site. Can someone explain what might have happened. It done that before too. Do someone else have to be streaming it for me to receive that site
As the others have noted, it's not normally receivable from your location.
To put it simply, the City of Cleveland designed their system to cover only the territory necessary, plus a little bit (basically, within the boundaries of Cuyahoga County). This is normal and proper system engineering. The only reason you were able to receive it was pure luck; atmospheric conditions allowed the signal to travel in your direction for awhile, and then it was gone. It has nothing to do with streaming or anything else.
If you really want to monitor Cleveland, look for an actual stream on Broadcastify.
