kn6msc
I built a 1/4 WL vertical with slopped down radials for 20 m (using a PVC post, and aluminum radiating vertical element, and insulated stranded wire for the radials) and managed to tune it well to SWR 1.1:1 and close to 50 ohms at 14.2 Mhz.
I've been having difficulty to get anything lower than 1.5:1 in similar verticals for 17 and 15 m. I kept reducing the length of the radiating vertical element, but the frequency of best SWR does not move up much from 17.5 Mhz.
In both, the 17 m and the 15 m versions ( with corresponding radials of the same length as the vertical element) seem to hit some frequency above which the SWR will not go down not matter how much I shorten the radiating vertical element and the radials....Is there some capacitance/inductance built in the system that prevents them from tunning well above certain frequency?
