Can't turn off record w/new 3.9 EZScan
roadkill97006
Beaverton, OR
I had a couple of talk groups defined with REC set to on. Up until now I have been able to select the talk group and toggle the REC setting. Now, in EZScan v3.9, I can't get the ones that are set on to turn off. I've tried it from the trunked radio systems page and the scanlist page and it's just stuck on. Am I missing something or have I found a bug? I've been scared to try another talk group.
roadkill97006
Beaverton, OR
Sorry 'bout that, I found it
It only turns it off if you hold the ALT key while you click it. I could have sworn that it didn't work that way before the update, but then again, I'm old....
roadkill97006
Beaverton, OR
It seems to be random
I just started 3.9 for the TRX-1 and toggled recording off/on for a talkgroup on a P25 system -- seemed to work fine just by clicking on it.
I tried it a number of times and it worked w/o the ALT key most of the time. Then I hit one talk group where it wanted it. I suppose a deinstall and reinstall will be in order.
