Cant update HPDB or firmware
kaiserfan
Saginaw MI
just bought Home Patrol loaed sentinal sofware but when i go to update HPDB or Firmware get failed message the remote could not be resolved: 'ftp.homepatrol.com can anyone help me
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
If indeed this is a firewall problem at your router, you will need to be able to sign onto your router's access through an admin password. If I just spoke Greek, I'd suggest you get in touch with someone that knows network administration
What OS are you running at your PC? You will need to also check the firewall there - and I would also check your antivirus to see if it may be the issue.
Mike
phask
zanesville
Where did you get the copy of Sentinel - with the radio or the download.
2.03 ver 4 is the current.
There have been issues with satellite internet users also.
jdm911
Northwest of Cloquet
I was getting same error after a recent Windows update. It was fixed after I went into a setting to revert back to system before the update, all fine again. I wish I knew though what the problem was.
QwKiE
Warren, Michigan
What is the Sentinel firmware version should be version 2.02 (revision 04). Open sentinel and look under help about.
kaiserfan
Saginaw MI
do you remember what setting or wher you went to?
jdm911
It was under control panel/settings I believe, there was a spot to revert back to earlier time or earlier status or something to that effect. (I am not using that computer at the moment but when I do I will try to find it again). It was pretty easy to find if I remember correctly. It was working up until mid Jan but then stopped after an update mid Feb so I went back to Jan.
kaiserfan
Saginaw MI
Would appreciate if you could check when you can and post thanks
jdm911
Control Panel\System and Security\Action Center-at the bottom of this screen is 'Recovery' That is what worked for me.
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
Most important question - what OS are you using, kaiser? Win7, Win8, ect. and what flavor - Home, Professional, etc.
Be very specific here - the answers you need are, to a certain extent, OS dependent...Mike
QwKiE
Warren, Michigan
If you won't answer us when we ask you some questions we can't help you we need to know some answers to help you.
kaiserfan
Saginaw MI
WinZP
QwKiE
Warren, Michigan
You could have an out dated copy of Sentinel on your computer that will never update, that is why I have asked you what is the version. Open Sentinel go to help, then about see what it says about your sentinel should be version 2.02 (revision 04) if its not you will get an error.
You can get the latest version of sentinel here.
HomePatrolSentinel < HomePatrol < TWiki
QwKiE
Warren, Michigan
That is an old version of sentinel you need to get the latest version of sentinel on your computer to get the latest updates for the HP1 the link is on the above post.
