Canton Area Medflight?
xusmarine1979
Louisville, Ohio
Anybody have any frequencies or anything for the Canton area Medflight? I got some 800 freqs from another source but not sure how up to date they are. Thanks.
FPO703
Planet Earth
Cleveland Metro Life Flight has a Helo based at Aultman Hospital in Canton. They operate on 155.3850
MedFlight of Ohio has 6 Helo bases, including 1 in Lodi and 1 in Coshocton. You would need to monitor the AEP system for MedFlight of Ohio.
FPO703
Planet Earth
For EDACS, you can only have one site/cell per bank. Make sure you enter them in LCN order with the first frequency in channel 01 not 00.
Since the AEP system is owned/operated by American Electric Power, I'd imagine the other talkgroups are used by the AEP crews.
FPO703
Planet Earth
You will hear AEP. If there is a MedFlight helo or ground unit in the area of that site, you will hear them. If they're not around that site, you won't hear anything
xusmarine1979
Louisville, Ohio
Ok, thanks. I see them in the air quite a bit around here and I've had 155.385 on my scanner but never heard much. Thanks again.
cann1995
London, OH
If you listen to the AEP Canton Tower & have the MedFlight talkgroups plugged in, you will be able to hear all traffic no matter which tower they are on. Unlike MARCS, they do not have to be in the area of the tower that you are monitoring. Example, MF3 can be talking on the Huntington WV tower & you can hear them on the Canton OH tower.
mmartinfan
Banned
In a house in Ohio
Make sure you use LCN for all AEP stuff.
Put in talkgroup 02-091 for air ops and 02-092 for ground ops.
Yeah they talk a lot.
smokeyspapa
Massillon Ohio
Does anyone know whether the AEP EDACS system in the Canton area is wide or narrow type? I live in Perry Township, between Canton and Massillon. I'm trying to program it in a Uniden 780 XLT and in the menu it has wide EDACS and narrow EDACS. I haven't had much luck with either setting. Any help would be appreciated. Thank you.
FPO703
Planet Earth
xusmarine1979 said:
I live in Perry too, do i need to set this "wide" on my Pro-96?
There's only one EDACS option on the PRO-96.
Just plug the frequencies in in LCN order and you're good to go.
curtainin
Another is 155.2650 is the tusc. co. med evac helocopter landed monday at aultman. Signal was loud and clear. There was an article in the Tusc. co paper about it a while ago. Looked green w/ white bottom not as big as lifeflight, still shakes my house though when flying by and landing.
