Canton/ Stark County TRS
w8jkc
North Industry, Stark County, OH
Any new TG's pop up guys? Some of these new ones haven't had much traffic.
For anyone still interested in this thread, I have made this page which parses the data directly from the Trunk88 files. It may help with finding out when/how much/etc the unidentified ones are being used.
http://www.w8jkc.com/8E0A/displaytg.php
This list automatically updates at the top of every hour as long as Trunk88 is running on my computer.
mtindor
OH/WV DB Admin
Carroll Co OH / EN90LN
Here are a couple of talkgroups that are very active today [and perhaps every day]. I'm monitoring the system from afar, so I can't get a good decode on the voice. But these two are definitely quite active. Any idea what they are?
2416
21392
Less active:
41136
41168
41616
Mike
xusmarine1979
Louisville, Ohio
2416
21392
Less active:
41136
41168
41616
Mike
21392 sounds like one of the colleges, they mentioned "campus". I'm just not sure which one.
I believe on Sunday, I was listening to a couple of guys doing some testing while driving around between Canal Fulton and Barberton, just checking random areas. They were checking both the trs and they mentioned their "400 radio" but I could not hear anything in Stark on UHF that sounded like testing. This was on 19984.
mtindor
OH/WV DB Admin
Thanks, Jon. If you're able to pin any of them down, please submit the info. I can't believe how active that system is. I've seen up to 6 channels in used simultaneously on it. I get good decode on the control channel. It's interesting watching all the activity.
Mike
jerk
jerkville
2416 maybe sounds like the water dpt. The dispatcher keeps talking about turning services on at different locations.
Yes turn on's and off's for delinquents, talk about missing manhole covers, etc... I would say this is Canton City Water.
jerk
jerkville
21360 is listed as Stark State Security... but all I'm hearing is the campus Shuttle, so it is close to 21392, it appears to be in a range that could be assigned to Stark State.
mtindor
OH/WV DB Admin
Hmm, 42128 is already listed as Canton Water Dept (and is in the same TG range as other Public Works / City Services stuff).
But the 2416 is in the low #s like only Canton stuff is. How about listening a little more and see if you guys can pin down for sure if this is Canton City Water. Also, let me know if you monitor anything on 42128 (the claimed Canton Water). Also need to know if this is analog. My guess is that it is. I wasn't watching yesterday when I saw the TG active when monitoring the CC, and I don't always have a good path to monitor it.
Mike
mtindor
OH/WV DB Admin
My apologies.
21392 is digital
2416 is digital
I will be listening and will keep you guys posted.
Ok I think I know what is going on. All 4xxxx talkroups in the DB are analog. It looks like Canton Water probably switched to digital, and as such they were assigned a new talkgroup below the 4xxxx range. I left the old Canton Water talkgroup in there, but I suspect all activity is probably on the new Canton Water talkgroup.
I'd guess that as other city services are moved off of analog [if they are], then they will likely be assigned talkgroups below 4xxxx as well.
Thanks for the info!
Mike
jerk
jerkville
Mike
I'll have to pay better attention, I listen, I identify, I don't pay attention if digital or anlog. And I submitted 41616 to night as City Collections-i.e. sewers dept.
41168 was active today, only reference was to bld. 6.
jerk
jerkville
TG 19984 Strange
I’m confused, two radio units were testing on TG 19984 Stark County, but all the locations were in Barberton and they went out at Barberton FD.
They did reference when I first hear them a Station 3, Belden Village?
So I was thinking Jackson Township, but addresses were all up in Summit County.
Though my guess right now is perhaps Jackson Township? Bears monitoring.
Unit numbers were 805 & 819 if that translates to a known FD
xusmarine1979
Louisville, Ohio
I believe that's what I was listening to the other day. Did you hear them today?
jerk
jerkville
Tg 41168
Is is looking like TG 41168 is Canton City Building/Code which is why they call the units building ##
It is for the city, not 100% sure of use, probably 75% at this point.
mtindor
OH/WV DB Admin
In your description, what's "Code" ? Is that supposed to be part of the description? I'll add it after I hear from you.
Thanks!
mike
