Scatpack16
Last Year we installed a new Cap plus multi-site system for a school district and it seems to be small problem after small problem since the install. They are running SLR 8000(4 per site) repeaters on UHF for the system and using XPR 3500e handhelds for the teachers and XPR 5550e mobiles for the buses. They have about 3 or 4 school buildings that can not hit the system when inside the building, but can hit it when they are right outside the building. We reached out to Motorola for BDA quotes but the cost is just too much right now. So I have been trying to find alternative options to get this signal into and out of the buildings (leaky coax, etc). Any ideas I can try would be greatly appreciated.
The other issue seems to be a roaming issue on the busses. Sometimes they hit the system and then sometimes they dont hit it even though they are in the same spot. I know part of the issue is going to be the issues with the coax and antennas (we have found some coaxes crimped out with pliers and producing high reflection), but it still seems like it may be a roaming issue as well. Thoughts?
