SDS100: CAP+
dazza0768
Timaru, New Zealand
I am in New Zealand
So we do everything manually here, we dont have the support like the USA for database stuff. We have to trawl and make our own.
Just wanting the proper way to setup CAP+, I understand to program as mototrbo but do I need LCNs for it to work and can I have multiple frequencies in the same site?
Whiskey3JMC
Keep your friends close & your radios closer
Land of Wawa & cheesesteaks
OK then. Program in all frequencies giving out data bursts as a new MOTOTRBO trunked system then run LCN finder (MENU > ANALYZE > LCN FINDER) to obtain the proper LCNs. Yes the proper LCNs are needed to track the system properly
Whiskey3JMC
MOTOTRBO Connect Plus
  • Multi-site trunking network
  • Maximum of 770 traffic slots
  • Up to 250 sites and up to 15 repeaters per site
  • Number of repeaters per site varies depending on number of traffic slots and sites (for example, 70 sites and 6 repeaters each, 250 sites and two repeaters each, etc)
  • Each site has a fixed control channel
  • XRT 9000 Gateway
  • XRC 9000 Controller
dazza0768
Timaru, New Zealand
  • XRT 9000 Gateway
Forgive my typo, CAP+
Whiskey3JMC
  • MOTOTRBO Capacity Plus
    • Single Site Capacity Plus allows voice and data communication at a single site.
    • Linked Capacity Plus (multi-site) allows voice and data communication at up to 15 sites.
    • Up to 12 digital voice talk paths (six repeaters) with three sites or less.
    • Up to 6 digital voice talk paths (three repeaters) with 15 sites.
    • Allows up to 24 additional dedicated data paths
    • No fixed control channel, instead has a "Rest Channel" (the next available slot, sounds like a control channel) which can hop around. In a standard installation, the rest channel starts at Channel 1 and works up to the highest channel, then returns to Channel 1 and begins the rotation again.
  • MOTOTRBO Capacity Max
    • Capacity Max allows voice and data communication up to 15 sites.
    • A system can support up to 250 sites and up to 15 repeaters per site, with up to 3,000 users per site and up to 100 voice talk paths.
    • Capacity Max is fully compliant with the DMR Tier III mode of operation.
    • Powerful management tools give you complete control over the system – all from a single workstation
    • You can also provision a second control channel per site for ultra-high system availability.
dazza0768
Timaru, New Zealand
Thanks for that info.
How do the LCNs generally look? Do they start at one and work up like a CON+ network does? Understanding the con+ that I've worked with starts at LCN 1 with the highest numbered frequency then goes to 2, 3 etc. Not like tier 3 which is patterned but all over the show.
