Capabilities of BR330T
WouffHong
Jawjuh :)
Just curious as my ancient PRO 94 is aging rapidly..
CAN the BR330T USB port/output be used with the default RR streaming software to stream the TAGS or frequencies as other Uniden Scanners do??
Tnx es 73..
Tom_in_GA
N8IAA
Fortunately, GA
Tnx es 73..
Tom_in_GA
Don't see why it wouldn't, Tom. Just out of curiousity, what is a TAGS?
Larry
bama9999
Gulf Coast
I may well be wrong, but I believe that he is referring to the alpha-tags, which can be seen when streaming with certain scanners.
WouffHong
Jawjuh :)
Tags from 330T
Larry
Hi, larry - Tags are a name sometimes used for the name OF the channel itself like "Boston EMS" instead of "155.34" :)
I capitalized it only for emphasis, not as an acronym.. :)
NOT sure if the 330T WOULD have RR-Stream Software Tag compatibility as the 996T and 396T do
73
Tom
WouffHong
Jawjuh :)
radioFeed
Tom, take a look at ProScan and RadioFeed...
ProScan
best regards..Mike
RR Feed aspect looks interesting, but "directions" for setting it up available - beyond basics. :) - Also might run a limited local feed off-RR for our Vol FD group an not sure how to make THAT work :) :roll:
Also I thought I had a FREESCAN registration, but can't find it.. Senior moment(s) :-(
73 es G'Bless..
Tom
Da Wouff
http://wouffhong.org
N8IAA
Fortunately, GA
73 es G'Bless..
Tom
Da Wouff
Tom, you don't need a FreeScan registration. Just download it at www.ScanNow.org
Larry
