Capacity Plus And Monitoring Private Calls
JASII
Memory Capacity
I am currently monitoring a two channel Motorola Capacity Plus system. They make extensive use of Private Calls. Is there a way to program a Motorola portable transceiver to monitor ALL Private Calls?
JASII
Memory Capacity
Private calls as in encrypted? No. There's no way to monitor an encrypted channel.
Sent from my HTC One A9 using Tapatalk
No, I mean Private Calls as in un-encrypted Private Calls on a Motorola Capacity Plus system. I can hear the Private Calls just fine on my Uniden scanner.
clbsquared
Isle of Wight County
I doubt it. It requires the radio to authenticate with the controller. Putting an unauthorized radio on the system would be a no no.
mikewazowski
Staff member
Forums Manager
Oot and Aboot
This is a Capacity Plus system not a Connect Plus system. There is no authorization or authentication required and in fact, you can check off the RX Only box on the channel setup on a Capacity Plus system.
ScanWI
MN & WI DB Admin
Wisconsin
There is no way to do this with a Motorola Radio at this time. Out of all the radios I have tried the only ones that have been able to decode the traffic is a Simoco DMR radio in monitor mode and a MD380/390 with the latest firmware that also allows for complete monitoring of a particular channel.
The Motorola radios are always looking for a valid TG or RID for them to open up. They have no way of monitoring any traffic on the channel at this time, that I know of.
N1GTL
CT
A DMR capable scanner but not with a Mototrbo radio.
