Care Flight?
Careflite
You Don't
Careflite Ground use Teletouch LTR which is passported, which means you only listen to the Channels and not the whole Talk-group. no currant scanner supports PASSPORT Protocol trunking.
Might check and see from the others here if Careflite use AirInc still. and Listen to the on MED-8 when they Give reports.
And .. there are Plenty of AMR Frequencies to listen to .... maybe its time to Plug them into your scanner.
RESCUE4NFD
GARLAND,TEXAS
Careflite Freq.'s
All the Dallas/Ft.Worth Air Medical Info. is here on the RR Database.Hope this helps.All Air Medical in the Dallas area give Pt. reports to their dispatch centers to relay to hospitals,or they use Med.2 (463.0250)
