Carilion Patient Transportation
svfire1
Buena Vista, Va
I was wondering if anyone had a current list of Ambulance stations for Carilion Patient Transportation Services? According to a map I found there are 8 stations that they run out of.
Thanks in Advance!
W4UVV
Prince George, Virginia--Central Va.
Maybe a little help
This is not exactly what you are looking for but it might be helpful. My database shows Carilion Patient Transports on 155.3250 mhz.at Roanoke and 464.8000 mhz. in Lexington. The hospital aircraft is licensed at Roanoke for 123.0500 mhz. I don't know whether or not it is outfitted for patient transport.
resqpig
Blacksburg, VA
To my knowledge unless very recently changed...Carilion Transportation is actually on 155.385 in Roanoke. I think the database has them listed as 156.240. 463.625 used to be a crosspatch with what I think was the Radford operations (Carilion runs as EMS in Radford). They may be on this still in Radford. 155.385 also is used for air operations (Lifeguard 10 & 11). I'm not sure of the other "stations" as they have agreements with many other jurisdictions to answer EMS calls, for example Franklin Co. and Bedford Co. They use the local EMS frequencies in these areas.
Hope this helps,
Kenny
