DSDPlus Causes of unrecoverable NID
jets1961
Like subject says: What are some causes of "unrecoverable NID" in DSD+.
I am running latest version of DSD+ (2p368) the system is 99.5% encrypted with AES256. The signal is very good and I have gain at 16.6.
I am noticing that some TG report weird Algorithm ID's when it should all be AES-256. The system is a Motorola phase 1 system.
a417
is it consistent with a particular TGID?
jets1961
I have not observed closely enough to say. But the I do know that currently the radio system might be patched to the next province over that being MB and SK.
As for the weird aglo ID's it's on a bunch of TG's all the weird aglos being reported are on a few TG's.
I use different folders for different systems in my setup. I update the base files at one point in one folder because I had a problem. I think I will try that for the system that is acting up. I know it used to work just fine a few months ago.
AM909
Radio/computer geek
SoCal
If you're using FMP24 as your tuner/demodulator, try adding option "-e1" to the command-line. If you're not using FMP24, try using it.
jets1961
Using FMP24, I will update base files tomorrow see if it fixes it then if not I will try "-e1". What is it's usage?
rivardj
Michigan
From the Notes file:
FMP24 2.74
Added automatic detection of I/Q stream dropouts.
Added automatic enabling of extra CPU loading to stop I/Q stream dropouts.
Command line change:
-e0: Extra CPU loading disabled; FMP24 will report I/Q stream dropouts in console window
-e1: Extra CPU loading enabled
-e2: Automatic enabling of extra CPU loading if I/Q stream dropouts are detected
Default is -e2
Active key change:
Pressing E will cycle through the above three modes
