Cb Antenna Reception near house
Jjoshjl
Greetings all. This is my first time posting here as I am new to radios.
Forgive me if this question has been asked but I am trying to set up a base antenna. I placed the antenna on a deck attached to my house and was curious if the house may be messing with the signal quality. My concern is the wall may be reflecting back signals and causing 'interference'
Thanks in Advance!
WB9YBM
things like aluminum siding, electrical conduit in the house--basically anything metallic--will have an effect on the signal. That's one of several reasons why it's best to mount an antenna as high as possible (if memory serves 20' above the roof if mounted to the house is legal limit). (The other reason is to get above the "ground clutter" (hence the adage "height is might").
Jjoshjl
I suspect I may need to break down and buy a proper base station... It's just a little magnetic mount I was trying to rig with a large metal plate underneath... Thanks
Jjoshjl
Any recommendations under $100? Im mostly looking to listen and talk to local area such as my Father in law up the road about a mile. Not really to be used as a mobile
MisterLongwire
Amateur radio operator/QC tech for radio mfr.
Banned
San Marcos,Escondido, CA.
Start reading some books prior to spending your money. If you're impatient, buy a 5/8 wave antenna. If you are using a 23 channel vs. a 40 channel, I suggest the yellow pages in your local phone book. Look up pyschotherapists and take your pick,/choice of candy. Seriously why waste your time.
KK4JUG
GA
Anything that's between your antenna and the radio you're trying to listen or transmit to can degrade the signal. That includes trees, power lines, buildings, etc. Some are worse than others.
Jjoshjl
Hahaha.... No it's not a 23 channel... Its an inexpensive mobile one I bough from Wal-Mart to play with...
LATA 722
A99 seems to be a commonly recommended basic base antenna.
Getting the antenna up high, and above the house, will help. Make sure you address lightning protection, grounding and properly waterproofing all your outdoor coaxial cable connections.
krokus
Southeastern Michigan
What are the dimensions of the plate? With 27 MHz, it needs a large diameter.
bharvey2
I was looking at mmckenna' signature...I had to chuckle. Got to have humor in these crappy times
Yeah, he hates everything, just like in the Life cereal commercials of the '70s. Mmckenna's first intial is M Just like Mikey. Has anyone ever seen them in the same room? Not that I've heard. Coincidence? Maybe.........
(Sorry mmckenna, I couldn't help myself)
LATA 722
Dammit, you figured me out. Now I gotta change my user name (again).
russbrill
Sacramento, CA
Hy-Gain Penetrator 5/8 wave antenna for cb radio and amateur radio... It runs about $150, and it's worth it... Something simpler and easy to put together, is the Antron 99, I think it costs around $100 without the ground plane kit..
WB9YBM
"Any recommendations under $100? Im mostly looking to listen and talk to local area such as my Father in law up the road about a mile. Not really to be used as a mobile"
[/QUOTE]
Ancient proverb: "You get what you pay for". In other words, if you buy cheap you'll most likely be disappointed and/or frustrated with the results.
