CB antenna
Ray_Davies
Vancouver
I grounded a mobile CB antenna to the center screw in a plug outlet in my house and got a very low match.
Does that mean it is broadcasting well? It is now on a concrete chimney with no ground plane.
spongella
N2HUN, Western NJ
Need more info. What is the make and model of the antenna? Some CB antennas require a ground plane for best performance. And, all outside antennas should be installed with lightning protection. A "low match" does not necessarily equate with performance.
It likely indicates that it is presenting something close to a 50Ω load. That doesn't mean it's radiating well. A 50 ohm resistor will show a low match.
As spongella said, more info needed.
And using the center screw on the outlet cover is not a suitable grounding point for an outdoor antenna. The ground on an electrical outlet is intended to be a safety ground for the appliance user.
prcguy
I've used or tried to use mobile CB antennas inside a house with terrible results. Think of all the wiring running through the walls putting somewhat of a shield around the room and if the house is older with plaster walls it probably has metal lath beneath the plaster further shielding the room from radio signals.
The only time I had ok results from an indoor CB antenna was with a full size dipole placing one element across the floor and the other taped up the wall and onto the ceiling. This was in a completely wooden structure and I maybe got a mile or so in the evening when noise and skip were low. A vehicle parked outside this house worked much better with the roof mounted CB antenna on the vehicle.
