Cb ball mounts...
Bigstuff95
wanting opinion on Cb. ball mounts? I've read or watched a video on used ball mounts being better than new one's? is that correct? I know they don't make lots of things like they used to, but in this case its an old electronic devise?, so how could that be better than new?
Not really "electronic", as there are no components inside it. It's just a mount.
Depends on what you buy.
The good ones are stainless steel. The cheap knockoffs are chrome plated.
As long as the insulators are in good shape and there's no obvious damage, one of the better quality older ball mounts would be fine. But not really any reason not to buy a similar quality new one.
Not many manufacturers anymore. I know they are out there, so you'll have to do some digging.
This whip won't be long enough for CB, but here's an appropriate mount:
prcguy
Over the last 50yrs or so I've probably had every ball mount made from Hustler to A/S to Motorola and everything in between. The best I've seen so far for a "regular size" ball mount is one sold by Motorola for the Micom HF radios. The ball is a black coated casting but the insulator is machined out of a solid chunk of black Rexolite and part of the insulator protrudes past the mounting hole for good high voltage arc protection. This mount will handle a lot of power and the insulator will last a lifetime. They were expensive new but can be found on Ebay occasionally for a good price. I believe the part # is TRN4505A and it was part of either the FAD-1400 or TAA-1000 antenna system.
My second favorite is the regular Motorola ball mount with stainless steel ball and grey plastic insulator.
It seems in the 1970s and maybe into the 80s there were more ball mounts to choose from and I think those from major mfrs were of better quality back then. I've run across more crappy quality ones in the last 20yrs than in the 70s.
Here is a pic of the Motorola/Mobat/Micom ball mount.
cmdrwill
So Cali
Motorola/Mobat/Micom ball mount. I had one on my Dodge W100 4wd truck. Never had any problems with those 'ball mounts'.
