cb base help
rambobill
Im trying to run a cobra 29 with rfx75 pushing 110 watts on a astron 20 amp power supply. radio turned on but when i keyed mic it died... i found an inline fuse blew on the radios pwr cord.... is the pwr suppy too large or small? also i hooked up a navaho base to my a99 and i recive ok but my swr meter was pegging to the max.... i did install the pl259 myself... might have messed that up? any help or advice is appreciated
RiverRat1976
Put a 5-7 amp fuse in the fuse holder and you will be fine. The rfx75 requires a larger amp fuse because it draws so much power from the radio. They do burn your radio up too.
