cb help
helvis
Oceanside
If all you want to do is talk a few miles down the road pick up a Cobra 29. That radio comes in different versions and all versions work well.
Next you will need some good quality American made coax, a good antenna and a way to mount the antenna. I'm not sure exactly what you're driving but I'm going to assume you operate a big rig truck. Since the tractors' cabs now are mostly composite / fiberglass... i.e. other than metal grounding the antenna is very important and should not be overlooked. Do you want a co-phased antenna set up or just a single antenna set up? the coax will differ depending on what you choose.
There is so much info out there. I recommend the Firestik.com site. There is a technical section there that uses lay terms and eases off the geek speak. Good luck to you. Glad to hear you are getting back into the hobby.
sdeeter19555
Reading, PA
If you can find an older Cobra 29 or Uniden PC76 or PC78, they are the workhorses. If you can find a reputable tech to go through it, that's about the best bang for the buck. Add good coax, and something like a Wilson trucker antenna; and you should have no issues getting the results you're looking for.
Sent from my SAMSUNG-SM-G730A using Tapatalk
RC286
Winnipeg MB
What is a good coax?
Sent from my SAMSUNG-SGH-I317 using Tapatalk
For single antenna mobile, some decent belden RG8X, if you want to co-phase, you need 75ohm cable. GR6 is good for that. (provided you are going to run barefoot. GR6 doesn't like high power).
sdeeter19555
Reading, PA
Make sure you search for a reputable tech if you go that route. ..there are a lot that say they're a tech that couldn't tune a radio correctly if their life depended on it. I only know of a handful that are worth anything.
usmc88222
Killeen, tx
Can u point me to one. I travel all over and can make my way to one? I really want to get this right. Thanks
krokus
Southeastern Michigan
Wirelessly posted (Opera/9.80 (Android 2.3.4; Linux; Opera Mobi/ADR-1309251116) Presto/2.11.355 Version/12.10)
If you're in southern Michigan, the guy inside the TA at the 167, on I-94 has a good reputation.
helvis
Oceanside
I have had excellent results from Snake Radio Customs. Look it up on the Interweb. The tech does solid work and I have set up all my friends with radios.
