CB mobile antenna question.
crackerjohn
Eastern Shore, Maryland
Hi:
I have a Chev Trailblazer and the roof is about 6 foot high. I park in a multi level parking garage at work. I have a Wilson 5000 with 1:1 vswr mounted on the roof with a Bearcat radio. Can I bend the whip at the base about 90 degrees and mount the mag mount base below the window on the driver side as long as the center coil is about equal or above the roof? What if the center coil is below then roof? Will my swr change?
Thanks,
Crackerjohn
kf4eyr
plant city florida
if its a magnet mount just pull it off and set it inside,,, that was the whole idea of having magnet mounts to start with,,,, my wilson 5000 is mounted on the roof of my blazer, but when i have to go into parking garages i just reach up and unscrew it set it in back and then park,,,,i know it is a pain but i rather have the edge of a hard mount,,,,,
Rred
Crackerjohn, the short answer is: No, don't even think about it.
And, yes, the SWR will probably change radically.
If your magnetic mount is too tall when used on the roof, try putting it on the middle of the hood when you have to enter low garages. That's not perfect either, but it is the only really simple solution.
