Avoid mounting the radio on the top of the dash. While there are companies that make mounts that install in there, and it can work, having your radio sitting there baking in the heat isn't a great plan.
Agree I'm definitely not going to do that.
Some install them inside the center arm rest area. If you don't need to mess with the controls very often, this can work just fine. You'd need to add a suitable external speaker. We've done this with a few VHF radios on newer GM trucks with full center consoles.
My only issue with this is the lack of access to the controls. I did consider it though.
Other option is to use one of the Uniden hand held remote head radios. The RF deck can be put somewhere out of the way and the controls/microphone just plug in. All you need to do at that point is to figure out where to put the microphone.
CMX760 Bearcat Off-Road Compact CB Radio with Mic Display
How reliable and solid are these radios? Do you lose much quality in performance/receive etc by going this route?
I used to use one of the Uniden CMX-560's in my 2011 F-150. I was using it for listening on a long road trip. It worked well enough for my needs. I mounted the RF deck behind the rear seat with the VHF radio deck. Since the mic/control head cable is just a simple 4 pair cable with RJ-45 on each end (Ethernet cable), I just made up an extension cable with a male RJ-45 on one end and a female RJ-45 jack on the other.
The small speaker in the microphone is pretty quiet and doesn't sound great, so adding a larger external speaker really helps.
Regardless of what I decide on I'm going to add an external speaker. Typically I have always had one but nothing fancy. In my other truck I have a cheap Midland speaker and it gets the job done but I've heard a lot of people recommend the DSP Clear Speech speakers so I'm considering one of those for this setup. Any thoughts on their benefits?
Just make sure you pull your power directly off the truck battery. Avoid the temptation to use cigarette lighter plugs or tapping into any existing wiring. That's the quick way to introduce unwanted noise into your radio.
And put a lot of effort into your CB antenna. If you want this to work well, you need to focus on the CB antenna. No cheap $20 antennas….
[/QUOTE]
I agree completely. I always run my power directly to the battery and have always been overkill with my trucks grounding etc. I am running a Larsen NMO 27 in my other truck and it works great. My only issue in this Ford is that I don't think I can run that same roof NMO 27 setup due to a Sunroof that covers the whole top of my roof. Also the new Ford has the aluminum body so that leads me into another problem I need to figure out regarding antenna setup.
Thanks for your input
