Antenna system matters most. The specific radio is almost an afterthought, by comparison.
SIRIO 5000 (lay over style) on PL-145 mag mount can’t really be beat for the type.
How to get coax out of vehicle is the problem to solve.
As a temp solution I’ve used memory foam with a “drilled” hole and a hard piece of tubing. Close window on the whole. Have to compress fairly far, so cut to spec.
An NMO-mount antenna would be a far better solution.
Agreed on PRESIDENT brand.
McKinley model isn’t big and offers “more”.
An external speaker brings up RX not apparent with most built-in speakers. KES-5 (used) is bomb-proof and time-tested. Could be mounted firing-forward into drivers footwell from under seat.
The earlier you start the more time you’ll have to become acquainted with use. It’s not plug n’play as to what’s to be heard.
Some radio traffic follows patterns, some does not. Accent, dialect and “bad” or poor radios in use by others only complicates matters. Many users thus just give up early on. Choose to be offended or can’t correlate what’s heard with what’s seen.
Some US regions don’t have much chatter. Mainly population-densityTime of day plays a role = late start driving at 0930 thru 1900 may not hear as much. In metro areas it’s from 0530 to 0900; afterwards it’s wrecks & lane closures.
AM-19 carries most truck traffic, 15, 17, 21 are GTG to keep tabs on.
Truck drivers tend to keep a radio on low and are monitoring for key words. “Mile Marker” is the big one, direction of travel is another.
See recent thread on Interstate travel.
