CB Radio Help
Claudiofish4
CANADA
Good morning.
I am going to be getting a new CD Radio. I live in Canada, Ontario, Toronto. Would a regular CB Radio be ok or does everyone now a day use SSB CB radios. What would be a better choice. looking at the uniden beartraker 880 CB radio and the uniden beartracker 980 SSB
KD8DVR
Elitist Ham
Columbus, Ohio
The 980 and its AM little brother the 880 suffer from failing displays, due to heat in a mobile environment. It is not advisable to buy this model if you will use it in a mobile.
Buy the President McKinley . It's a better radio anyway. If you decide on an AM only radio, any of the President line is first rate
bpittman
Berkeley Springs, WV
By all means get one with SSB. You can always listen to AM signals on a SSB radio but can't listen to SSB on a AM radio. If the next sun cycle ever starts you should be pleased with SSB.
cralt
Yea the 980 where the best to get a few years ago but President stuff is the new leader in my opinion.
I agree with the the McKinley recommendation. It does AM and SSB. I owned one and it was a solid radio. Sold it to a friend to help him get on the air and he has had zero problems with it.
The only negative I can think of was I never got it to work right with old style dynamic mics. If your fine with the stock mic then that is a non-issue.
It DOES work great with the Bearcat wireless mic.
KD8DVR
Elitist Ham
Columbus, Ohio
Yeah, the McKinley requires an Electret-type microphone. Some of the newer presidents can be set to either a dynamic type or electret type; but not the McKinley. The cheapo Cobra 19 series, I believe also uses an electret type microphone.
n7lrg
Another vote for McKinley here. I have two now. I run one as a base station, the other in my truck.
hoskinmage
stanford,kentucky
Good morning.
I have always had good luck with the galaxy rDios but in my opinion I think the older radio is voyage radio,vr 9000 for a moble and a eagle 5000 is a good one for a radio that stands by itself or if you want to run power then try the eagle 2000 it's the radios I own and I wouldn't take anything for them. There is a lot of good radios out there but I've found that galaxy is one of the best.
