niceguy71
getting my mobile going... grounding the pick-up truck this weekend... and I have Best Buy wiring a relay on the 16th so when I turn the key on it will let power go directly from battery to CB... for now it's wired to the cigarette lighter... anyway....
I've got the SWR decent for now.............. my neighbor saw me putting a CB antenna on my truck so he put his on his car... I was going out to supper 20 miles away so I said I'll talk to you on the way and see how far we get.... this was at 3:30PM and I think the CB conditions were not good.... my signal meter on the CB was at 7 on all channels... .. we talked for 3.5 miles .... I noticed every time I keyed my mic the needle on the meter would only go to 5 to 7???? it normally goes into the red almost full scale when I talk on it???? so after I had supper I'm heading home and try to get my neighbor and noticed the conditions were now good... and my Signal meter when I talked was now going just about full scale again???? does atmospheric conditions change what my transmitting meter will show???? I never knew this if that's what happened???? or was this just a coincidence? ???
SWR picture just for a before... and I'll see if RF bonding the 4 corners of the bed to the frame... four corners of the cab to the frame and bonding the bed to the cab.... also bonding the hood and fenders..... and adding a few better grounds....I'm not moving the antenna and I'll see what the SWR is after this weekend.
