CC display on P25 LSM systems (PSR-500)
CqDx
US
Hey everyone,
For some reason my PSR-500 does not show control channel info on the display screen and does not produce CCdump info when tuned to a new 800MHz P25 Phase 1 LSM control channel. The scanner display DG on the left side, but no WACN, NAC and other info on the bottom. The signal is 5 bars so it can't be weak signal causing the problem.
With the identical settings on the scanner I tried a older 380MHz military system, 800 Type II smartzone system, they all work fine with unitrunker and the radio sends ccdump data flawlessly.
any thoughts?
Jim41
Hey everyone,
any thoughts?
Whjile scanning this trunked system press FUNC and TUNE. What is the decode rate (in %) that is displayed?
Is this a simulcast system? If so, your radio may be having problems decoding the control channel.
See this Wiki article: http://wiki.radioreference.com/index.php/Simulcast_digital_distortion
Jim41
CqDx
US
I get 95% decode rate when pressed.
Yes the system is a 5 site simulcast system.
Jim41
Since you are getting a 95% decode rate, I am at a loss to identify a reason for the behavior you are seeing. Maybe GRE Support could help.
Jim41
CqDx
US
Will open a ticket with GRE
Thanks Jim41
