CC-Dump on 500 & battery usage
W2SJW
Senior Member
Northwest NJ
A quick question here guys:
Does leaving CC-DUMP on all the time accelerate battery drain on the PSR-500?
mikey60
Oakland County Michigan
I don't think so, but I suppose you never know. There was an update to a firmware version (I don't remember which one) that added a command to the PC/IF port where software that uses the CC_DUMP data (like my Pro96Com) can turn that on remotely. I don't know if Unitrunker has implemented that command or not.
If you're using Pro96Com, you can just leave that setting off, and the program will turn it on when it needs it.
Mike
DonS
Franktown, CO
Looking at the schematic, it's conceivable that running "CCDump" will cause some additional current drain. However, if you don't have anything plugged into the PC/IF jack, it's on the order of microamps.
Prior to the firmware updates that allow software to change the CC dump (other than re-loading the radio's memory) I normally ran the radio with this feature on - even when using the radio as-is. Unless there was lots of audio or I needed to use the backlight frequently ... I got decent battery life.
btritch
Out of curiosity What is the CC Dump anyways? I'm not sure if mine's on or off, I'll have to look but curious what it is ?
mikey60
It's a feature of the PSR-500/600 that will feed the received control channel data out the PC/IF port of the radio. Decoding software like Pro96Com and Unitrunker can then use this data to display the system information on the computer screen.
Mike
mikebennett
Sherman, TX
Press PGM, then FUNC, then F3 (GLOB).
Press FUNC, then the Down Arrow. Then scroll up one spot to the CC_DUMP option.
Mike
Okay. I was trying to get to it through the current system, not global. Thanks.
mikey60
What does the DSP Dump do?
It's supposed to send out information about the communications between the DSP and the CPU. I don't know of anything available that would decode that information to anything usable, so it would be best to leave that option off.
Mike
WayneH
Forums Veteran
Your master site
When I found the bug with P25 and 3xx NAC's I used this dump to send to them.
So it's basically for debugging and makes it easier for the support team.
