CC lockup
edwardscott
Anyone know what would cause a BCT8 scanner to lock up on the CC?
Been having that problem with the Sunderland Fleetnet tower lately, but only on one scanner ... funny thing is, its set up the same as the others. Its programmed correctly, band plan etc, but locks up on the CC. Manually, you can hear the voice channels fine, as well.
Anyone have any ideas?
Thanks!
ES
mciupa
Canadian DB Admin
Moderator
I'm here a lot
It may have the band plan, correct freq's... etc , but if it was programmed in conventional mode and not trunking mode (with that little M on the display) , then it won't operate properly.
Trust me, if there is a mistake to be made , I've done them all at least once. :roll:
