cc lockup
edwardscott
Anyone know why a trunked system, when programmed properly, would lock up on the control channel while in ID search mode? It's an 898.
Thanks in advance,
ES
I post, you post
DaveH
Ottawa, Ont.
Which system are you referring to, and the system type?
Is it VHF/UHF, or 800/900MHz?
Also, what dou you mean by "lock up"? It is normal for
the scanner to lock to and EDACS or Moto CC but you should
not hear it.
Dave
edwardscott
It's VHF, sticking to the CC for Sunderland Tower on Zone 1 of FLeetnet on both scan and search modes.
I realize that is normal, but this is not. It literally locks onto the frequency.
Thanks for you help,
ES
not hear it.
Dave
slicerwizard
Toronto, Ontario
Well, you say it's programmed correctly, but it doesn't sound like it. Incorrect bandplan programming could lead to your symptoms. Landing on another site's control channel could also do it. What exactly shows up on the display when this happens?
DaveH
Ottawa, Ont.
Sounds like some or all frequencies were programmed in conventional
mode, but should have been in trunked mode. I don't know exact details
of the 898 but believe it's a souped-up 895, so probably similar programming...
press/hold TRUNK until it beeps twice, select the bank to program, and enter
frequencies.
Dave
edwardscott
Hmmm...maybe it was programmed in conventional, I'll have to check. I'm actually inquiring on behalf of a friend.
When I checked it out, I checked to ensure the bandplan was put in right, which it was. But the CC may have been put in conv somehow.
Thanks for the help,
Cheers,
ES
69stiles
Waterloo Region
I bet if you check the system mode it is set to fm or vhf instead of MOT(motorola). All channels need to be set to MOT.
