sean_kd4adv
Name here is Sean, KD4ADV (General)
I have a CDE/CDR Control box and my needle has stopped moving to indicate the direction that the 2 antennas on the mast are pointing.
I have to get up and look out the window, or look at the signal meter on the rig to indicate whether the signal is getting stronger.
I am unable to work on the inerts of the box.
The connections on the rotor and the box are secure.
The lamp always blows out whenever I replace it.
I bought it used along with a HF5B "Butternut" antenna and a 2m VHF beam back in 2005.
I would like to get another control box that has 8 terminal connectors.
Before I go out and buy another control box, Is there a compatibility concern about using antenna rotor control boxes with rotors? (i.e. name brand?)
Reminder - ***Frostfest 2014 is coming up on Feb 1, 2014 in Richmond, VA at the State Fairgrounds complex.*** Sponsored by R.A.T.S. of Richmond, VA Talk-In will be on the 146.880 / 146.280 (input) Repeater with a 74.4 Hz PL tone.
