CDM 1250-no audio
Northeast Nebraska
Guys, I have dusted off a CDM 1250 and going to use in my car. Come to find there is no audio from the speaker. There is a harness coming off the rear of the radio. I need to know what pins or what to jump to get sound out of the speaker, or will I need to use an external speaker?
fineshot1
NJ USA (Republic of NJ)
Sound should be coming out of the speaker regardless of how the accessory conn is wired.
See the batlabs web site below
HT750/1250/1550/PRO5150/7150/9150/GP320/340/360/380/ GP318/338/GP640/680/1280/CDM750/CDM1250/CDM1550,etc.
DPapay
Morris County, N.J.
Carefully pry the front panel off the main chassie, try to keep them close together, to not rip the flex cable. Look to see if the internal speaker is plugged into the pcboard. If it is, do you have a way to check the speaker, ohm meter. External speaker pins are 1 and 16. Looking from the rear of the plug, with the tab up, pin 1 is the lower left, pin 16 is the upper right.
Make sure to re-seat the pcboard into the little tabs on the housing before you pop the front back onto the chassie.
jim202
New Orleans region
Make sure you don't ground either side if the speaker wires. If you do, you will blow the audio output
IC. The batlabs diagram that another person gave you the link for should provide you with the pin
connections on the accessory connector for the internal and external speaker.
Jim
