CDM-1250 question
Markscan
New Jersey
I am going to program a CDM-1250. The cable I have has four different connections on the end. Can I program using the microphone jack, or do I need to get at the back of the unit. Its mounted in an ambulance console, so the front jack would be easier. Thanks for any help.
SD70MAC
NC
Cdm
Mark,
If the radio is all in one piece in the console you can do it through the mic jack,if its a remote mount it is best to go from the 20pin jack on the rear.
CDM's are easy to screw up and get a EEPROM CS ERROR so DO NOT USE A USB or USB converter you will be sorry. It my not get you at first but this setup is a ticking time bomb. I like the Waris radios but they have some quirks.
N1GTL
CT
The newest programming software can clear this error. When you connect the radio and read it, you will get an option to restore the radio settings.
wa6ylb
Central California
You can program the radio from the front (with the ribless AARKN4081B cable) or use a rib one on the rear of the radio.
B.
