CDM-1250 shutting down
Mr_Observer
Wirelessly posted (BlackBerry9630/5.0.0.591 Profile/MIDP-2.1 Configuration/CLDC-1.1 VendorID/105)
My first thought would be that you have something loose in the ignition sence wire setup. Like a loose pin or a bad fuse holder crimp.
cifd64
Northern Passaic County, NJ
Nope. I checked all connections. Even tightened some of them up during a recent install. Everything is nice and tight. The radio has been beat up over the years. Might be time to upgrade. Thanks though.
RKG
Boston, MA
Next thing to check is voltage fluctuations, either in the ignition sense line (low voltage can be read by the radio as a command to power down) and the chassis power line (low voltage can trigger a shutdown to protect current-driven components).
