CDM 1550 LS + error
dixie729
Daviess Co., KY
Im trying to add some channels to my radio. When I click "read radio". I get the message "cannot create unknown radio component" on my laptop. Can anyone tell me why?
Im using Windows 7 and Vista. (laptop)
Worked on computer using Windows XP. (desktop)
CPS - R06.11.07
NCFire11
Depending on which version of Windows 7 you have, you should be able to run the program in "XP mode." That should work for any program. Its certainly worth a try.
SteveC0625
Northville, NY (Fulton County)
It is well documented that this won't work on a 64 bit Win7 machine. A lot of folks have spent a lot of time trying to do this, and they all report ZERO success.
A lot of folks have also reported problems with USB to serial adapters on the newer computers. Some have found combinations that work and some have not. Again, using a PC with a real serial port eliminates the potential for problems.
I installed the Pro CPS on an older XP computer that has a serial port, and things just plain work the way they should.
NCFire11
You say you have 7 and Vista? Which one are you exactly using, or do you have dual boot? And yes do you have 64 or 32 bit OS?
I have been able to read and write to a radio using a 64 bit Win7 desktop in XP mode. I guess i am the 1%.
SteveC0625
I believe it is the Windows 7 Home Premium 64 bit version that does not have a true Virtual XP mode available. The Professional version of Win 7 does. Unfortunately, the Home Premium is what most folks buy.
dixie729
Daviess Co., KY
Thanks for the input guys. Guess I'll continue to use my desktop computer that runs XP. My radio is mounted in a console and is hard wired. I was trying to get away with having to take it out of my truck but oh well.
SteveC0625
I have exactly the same setup. I bought a 25' serial cable that reaches from my home office to the driveway. Since I have the serial version of the ribless cable and a regular rib (serial also), it has been no problem to pull the truck in the driveway, run the cable out there, plug it in, go back into the office and write to the radio.
I've also used a 9' plus the 25' with no issues so I expect that even a 50' serial cable would work just fine.
maxkelley
FN13GF
Download VirtualBox Oracle from here: VirtualBox Downloads and install it. Then, create a new virtual machine and install Windows XP (you'll need a disc, or a disc image). You can then route one of your physical com ports or your USB-serial adapter to the com port on the virtual machine, and it should correct your error. It worked for me on a Windows 7 64-bit machine!
