CDM 1550
LawlerJr
MA
I bid on a cdm 1550 on eBay and have won it. I didn't do alot of research on the specific model #. They gave me the freq it covered and I understand not all the 1550's are 160 channel.
Anyone have insight into this model #
AAM25SHF9AA5AN
SteveC0625
Order of the Golden Dino since 1972
Northville, NY (Fulton County)
AAM25SHF9AA5AN
450-512 MHz
25 Watts
1 Line Display, Standard Keypad
Conventional
128 Frequencies
There's a model number chart and more info about these radios at http://batlabs.com/htpro.html
It would be a wise move to print out this info and save it if you plan to work with these radios at all.
SteveC0625
Another question springs to mind: Have you given any thought to how to program this radio and what you are going to use it for?
Skypilot007
Medford, NJ
If you need it to do the 440 Ham band it will work quite nice for that. I have several 450-512 split CDM's working great on 440. The Mod is not that hard once you aquire the correct version of CPS to program it with. You will also need to know what the last version of CPS that was used to program it as you will need that version or newer. The latest version of CPS will lock the radio down in narrow band. You will have to jump through some hoops with motorola to get the entitlement key to get normal wide band operation if you use the latest version of CPS. Have fun and good luck with the new rig.
LawlerJr
MA
I have the ability to program it. I am on a regional dive rescue team. It's nice not to need a scanner and a separate mobile.
