CDM 1550
agnt549
I Have A CDM 1550LS+ DP6 I Have the CPS Software When I Go To Read The radio I Get A Message Saying the Radio Is Unsupported So My Question Is What Is DP6 And Way Is The Radio Unsupported I Have Programed 1550 Before With No Issues Or Problems Thank You
1/4 wavelength away
The smart *** in me wants to say you have the wrong mounting bracket....
I seem to remember seeing that message with some Latin America radios, I think it was the pro HT series portables, they had a different version of software.
radioman2001
New York North Carolina and all points in between
DP6 is Passport trunking, What level software are you using and what version. If it's NA that should work unless you have a LA radio which the model number will start with LA and not AA. There is a hack to use any software on any version radio including Chinese, but you will have to find that on your own.
cmdrwill
So Cali
" CDM 1550LS+ DP6 " here IS your first clue,
DP6 may be a after market, NOT Motorola, option, that uses a different software.
SteveC0625
Northville, NY (Fulton County)
There is a version of the 1550LS+ that includes DP6 in the model number. The correct last 6 characters of the model number would be 9DP6AN which makes it a Passport and LTR radio with 160 LTR frequencies. If memory serves, that version can only do 16 conventional channels.
Regardless, it needs the Passport version of the CPS. It can not be programmed with the Conventional Professional Series CPS.
The region hack for the Conventional Professional Series CPS probably won't work on the Passport version.
The OP really hasn't given us much to go on. He should have provided the complete model number plus the full name and full version of the CPS that he is attempting to use. Since there is also an LA (Latin America and South America markets) version of the 1550's, the full model number is even more important.
FWIW, there are a number of previous discussions here on RR about the Passport version of the 1550LS+ that should answer most any question he has. Easily found with a tiny bit of a search.
radioman2001
Not correct you can have a HT-1250 or CDM-1250 with DP6 firmware, and the radio uses the standard software if it's the right region. The Passport board uses a separate software included in the main software package. Like has been posted the last 2 digits will tell you what region as will the first 2. AA=USA LA=Latin America FD=Federal Govt. CN=Chinese
The only way around is to do the Region Bypass hack. Look it up.
