Cdm quik-call
Cmalan1213
glastonbury, ct
So im working with a cdm1250 as our main building alert system. Right now we have our duty tones and our hospital diversion/announcement tones. We just set up a chief tone that we also want the overhead page with. Because non of the tones are the same i have it set up as duty tones A/B hospital diversion C/D. (Yes i understand the easy fix is to use a combo of the duty and diversion tones for the chief but we cant)
I noticed that after the signaling tab is a tab labeled call. When you open that tab up you get a drop down labeled quik-call II call. When under this tab it lets you pick a quik-call system, along with a call format and another set of tones. Is this going to let be add the 3rd pair of tones in?
Also i would love to have each set of tones page a different call alert. Is this at all possible?
Thanks in advanced.
CommJunkie
FN20jf
Each personality can only allow one configuration of QCII tones. So creating a second QCII personality will only be able to be used on a seperate channel.
Channel 1 cannot decode both Quick Call II System - 1 and Quick Call II System - 2 signals.
The Quick Call System under the "Call" menu will allow another set of tones to be sent, but not received.
