CDM repeater duplex cable programming
K2NEC
5F6
Under Radio Configuration>Accessory Pins there is an accessory package dropdown option. Select RICK TX/RICK RX appropriately according to whether the radio is the transmitter or receiver
n2qjn
HOPATCONG
Thank you, unfortunately that did not key the transmitter. Everything works if I use a controller just not with the duplex cable.
K2NEC
5F6
Well you also bought a $7 cable off ebay, can't really expect much from that
Use a genuine RICK or at least a half decent interface. I have an aftermarket one that actually has a small interface box and not just some boards on the connector
n2qjn
HOPATCONG
Yha i know..LOL...
Well as an up date, it works, Thank you for your help. You would figure the TX and RX labels woud face UP. Well, they don't they face down switching that corrected the issue. Thank you again
