CDM Vehicle Repeater Issue
mgriswold
Binghamton, NY
Alright, I’m just starting to diagnose the issue but figured I’d enlist some help. What we are looking at is a vehicle repeater utilizing two CDM series radios on VHF and Low Band and an OEM Motorola Rick.
The problem is whenever you talk on the vhf portable through the repeater to low band there is a “cycling” issue every 2-3 seconds with a brief click. Looking at the radios neither one is visible in creating the issue. The low band has already been swapped with no change in the issue. It does not do it talking low band to vhf though. The vhf radio is next to be swapped but it is buried in the truck.
First thought is maybe receive sensitivity is off on the vhf radio? But band split being far enough apart I would think wouldn’t cause and issue there. Any suggestions?
kayn1n32008
ØÆSØ
Sector 001
Is there priority set on either radio?
RKG
Boston, MA
Long distance, sight unseen diagnoses aren't worth a lot, but I'd be inclined to investigate voltage drop. Key the input, receiver unsquelches and keys transmitter. Voltage drops, which causes input receiver to drop qualification, which causes output radio to unkey, which allows voltage to rise, which causes input receiver to requalify, and so forth. Engine running or off? Output power of output radio? Condition of battery and alternator? Wire size? Condition of connections, especially the grounds?
mgriswold
Binghamton, NY
That was one of my first thoughts as well, seems to all be good but I haven’t officially ruled that out as of yet
jeepsandradios
East of the Mississippi
I installed many of these in the past in fire trucks and ambulances. Where are your antenna's mounted in relation to the RICK. I found that a side mounted lowband ball/whip next to the officers seat would cause all sorts of crazy interference. We started moving the RICK and radios to the drivers side for those applications. I would also check antenna match on all.
