CDM1250 CPS password lock
Santa Ana, CA
Hello,
I just purchase a used CDM1250 UHF and when I came to program it on the CPS it shows CPS Password required. Since I purchased this item used online the seller never gave me the CPS password. IS there any way around this? Can anyone e-mail me a code plug to overwrite the password? Thanks for your time.
Skypilot007
Medford, NJ
What is the exact model number of your radio? You will need a code plug from the exact model number for it to work. Also what version CPS are you using?
MPFD535
NJ
Pm me the model number also ill check the ones I have. I had that problem once nothing to worry about
C138NC
Tactical Taco Consumer
NC Taco Command
Since this is up would there be a way to find out the same for a VHF CP200 or would i need the exact model number as well?
n7maq-1
Oregon
If you check on the Batlabs forums you find the info need to edit the CPS so you can bypass the password.
Jim.
Santa Ana, CA
Will getting the code plug of the exact model and writing it work? I tried this on a HT125LS+ we had using CPS 6.10.04 and it still asked for the password before writing? Please let me know.
kato
re: Password
Hacking the CPS worked for me with a 1250LS+ that was passworded. Once fixed, and even though the CPS still asks for the password, you can continue to view/edit the codeplug.
